oil change problem
I just changed the oil and filter myself for the first time since I bought my used 1985 911 Carrera Cabriolet. I used only the lower drain plug and seemed to drain about the right amount of oil. The problem is that now I have virtually no oil pressure at all. Any magic (and hopefully simple) answer?
RE: oil change problem
how much oil did you put back in? And you need to pull both drain plugs.
just retrace your steps and check the plugs and the filter....
