-   -   Transmission/Engine Noise ??? (https://www.germanautoforums.com/forum/porsche-911-8/transmission-engine-noise-5392/)
pockets Mar 5, 2008 05:34 PM
Has anyone had this problem or can you suggest what to do? I have a 99' 911 (6 speed) and the engine has been getting louder over the past few months. It happens when I drive over 35 mph. A local shop heard it and he says it's the Main Bearing and I need a new transmission.
He estimated it will cost about $7,000. My car has about 80,000 miles on it and I can't afford to dump that much $$ into it.
... help !!!
PorscheDoc Mar 5, 2008 07:11 PM
RE: Transmission/Engine Noise ???
Sounds like you need a new transmission.
cmilam Mar 5, 2008 07:47 PM
automatic or manual?
pockets Mar 5, 2008 08:13 PM
Manuel.
PorscheDoc Mar 6, 2008 07:24 AM
The only other option it would be would be the release bearing, but you should feel a difference in the clutch pedal if that has gone.
pockets Mar 6, 2008 01:26 PM
I haven't really noticed a difference in the clutch or anything. I might just limit the use of that car until I can get the $$ to fix it. Any recommendations on thta. There's a Porsche dismantler in Los Angeles that sells rebuilt transmissions for about $3500 with core trade. Then there's the labor. ....
Is this a common thing on 911's, or what could have caused this?
Thanks for your replys
