Porsche 914 The Porsche 914 was a sports car built and sold collaboratively by Volkswagen and Porsche from 1969 through 1975.
1972 1.7 fuel delivery problem. NEED HELP!
Old Feb 15, 2008 | 11:19 AM
AuToUnIoN_77's Avatar
Default 1972 1.7 fuel delivery problem. NEED HELP!
This car cranks wounderfully, could probably crank it for an hour straight without a problem, but she wont pick up! I know i have spark, ive used a spark tester, and it lights up. ive replaced lugs with bosch platinum's, and i know my points are good, their dwell and what not are fine. i pulled the injectors, and they didn't look so good, but i umperwired them to the battery and they all click, so i THINK their okay. (i will probably replace them reguardless). the ECU runs the fuel pump pretty well, and with the fuel rail disconnected there is a stream. (not sure if i have enough fuel pressure). I am also going to have the ecu rebuilt. i know there is a spot on the distributer that is used to ground out the injectors, could that be messed up?
In great need of suggestions.
Old Feb 15, 2008 | 11:21 AM
Default RE: 1972 1.7 fuel delivery problem. NEED HELP!
i meant to say i replaced the PLUGS, and i JUMPER wired the injectors.
WhatSpeedLimit
Jul 25, 2012 12:25 PM
porsche434
Feb 21, 2009 04:41 PM
Williama
Jan 18, 2008 02:35 PM
serg
Sep 22, 2006 10:47 PM
