1972 1.7 fuel delivery problem. NEED HELP!
This car cranks wounderfully, could probably crank it for an hour straight without a problem, but she wont pick up! I know i have spark, ive used a spark tester, and it lights up. ive replaced lugs with bosch platinum's, and i know my points are good, their dwell and what not are fine. i pulled the injectors, and they didn't look so good, but i umperwired them to the battery and they all click, so i THINK their okay. (i will probably replace them reguardless). the ECU runs the fuel pump pretty well, and with the fuel rail disconnected there is a stream. (not sure if i have enough fuel pressure). I am also going to have the ecu rebuilt. i know there is a spot on the distributer that is used to ground out the injectors, could that be messed up?
In great need of suggestions. |
RE: 1972 1.7 fuel delivery problem. NEED HELP!
i meant to say i replaced the PLUGS, and i JUMPER wired the injectors.
| All times are GMT -5. The time now is 09:43 AM. |
