1973 914 fuel inection is not spraying
hi, my name is william i have a 1973 914 with a 2.0L and the injectors are not sparying fuel. i have changed the trigger points and is still not operational. any suggestions is appreciated. (also the injectors have been changed)
Try to replace with a known good injector (used), or new. Have you tried re-building the carburetor? Could be internal float is bad?
