-   Porsche 924 (https://www.germanautoforums.com/forum/porsche-924-12/)
-   -   924 Engine advice wanted (https://www.germanautoforums.com/forum/porsche-924-12/924-engine-advice-wanted-1356/)
1984cc Jan 9, 2006 06:08 PM
Hey
im currently considering buying a Porsche 924 from 1977, a black one, a real beauty!
the car is in good condition except that there is a problem with the Fuel Distributer, the guy says that it needs cleaning or in the worst case replacement. so im wondering what is the cost of having a shop clean it or is it something you can do on your own? And if it needs replacement, what is the cost of that?
also, some other advice for a first time Porsche 924 buyer?
thanks,
Erik
PorscheDoc Jan 9, 2006 06:31 PM
RE: 924 Engine advice wanted
I am not familiar with the 2.0L 924s, but if the fuel distributor is like the 911's, then you can get it cleaned and refurbished by CIS flowtech in alabama. I *Believe* it is around 400 bucks. If you get to that point, and want more info, i can get ahold of larry and see what he is charging, etc. It will require you pulling the fuel head, and sending it in. Turn around time is typically 2 weeks. It is not something you will want to tackle yourself.
1984cc Jan 9, 2006 06:48 PM
hmmm..
i forgot to mention that i live in europe :P
anyway, why wouldn't i wanna do it myself? i consider myself at least somwhat technologically competent, and if it does not require special tools, i would at least like to give it a try! ;) do you know of any good references (books, etc.) that deals with these kind of problems?
erik
PorscheDoc Jan 9, 2006 09:32 PM
Well, there are very few companies that rebuild the fuel heads. That there should tell you something about how easy it is.
CTiggerPigglet Jan 10, 2006 12:34 PM
Hello Erik,
If your 924 is from '77 it must have the V.W./Audi based engine. I don't know for sure but, wouldn't the fuel distributer be the same as a V.W./Audi with this engine?
If so, this part might be quite cheap to buy and not worth re-building. I would also think it would be quite easy/cheap to purchase a used one from a Porsche breakers yard?
Either way, I would phone around and ask, before re-building it.
What part of Europe are you based?
1984cc Jan 10, 2006 12:45 PM
I live in belgium,
anyway i found this http://www.specialtauto.com/fuel-distributors.html on the net, and 370 dollars is not a bad price, over here they take between 1000-1300€ for a fuel ditributor! I went and asked a local mechanic and he said that he would clean it for 80€ but without a guarante that it would work and install a new one for about 100€. so my problems are solved it seems like :D
CTiggerPigglet Jan 10, 2006 12:58 PM
Great to hear it!
Why not post some pic's of your 924 in the gallery when you have time? As you say, in that black paint, she must be a beauty!
[sm=Flahssssss.gif]
1984cc Jan 10, 2006 04:10 PM
she sure is! although the color might be a dark dark blue, i have only seen the car in the dark ;)
