HELP with 928 - heat and idle issues
Old May 24, 2009 | 10:56 AM
boatboy_srq's Avatar
Default HELP with 928 - heat and idle issues
Hi folks!
I just found this forum and, having had my baby for ten years now, thought I'd throw this out for discussion.
She's an odd bird: everything onboard is straight 1987 928S4 except the wheels (17" five-spokes v. stock 16") and the block (which is circa 1993 GT product). ORDINARILY, she runs fine, BUT:
- When she's warm (NOT from cold start), she tends to stall out at idle. I can keep her running with a toe on the gas but that gets annoying. Idle + 150 rpms (650-700 range) seems to do the trick.
- In warmer weather she heats up dramatically. It generally takes 80+ F for this, but more than once she's gone from fairly cool to blowing hoses in half an hour. Driving conditions (open fwy or heavy traffic) don't seem to matter much.
I've replaced the entire cooling system (yes, with OEM parts, radiator to water pump), and I've had some stellar mechanics look into what makes her run like this - so far without closure on either item. I'm just about to dust her off again (she's been in storage for a while) and I'm debating whether to take one last shot at solving her quirks or just chuck it in.
Any suggestions?
Old May 25, 2009 | 09:56 AM
Have you done a leakdown test on the motor recently? Might be worth looking in to.
The idle issue sounds like a stabilizer valve, tps issue, etc. My 928 knowledge is limited.
strawmiller
Dec 11, 2011 10:57 PM
northcoast944
Aug 26, 2009 04:06 PM
Ed in Holly Springs
Feb 3, 2009 10:06 AM
1989 rott 951
Jul 12, 2007 10:52 AM
rlrobian
Oct 10, 2006 10:02 PM
