1983 944 - Blower Motor Question
My Heater control will not turn the Blower Motor on, had the Motor Tested. Works great, checked for voltage to the Resistor and no Voltage. Went to the switch inside and checked for voltage and still none being found. Fuse is good, and no voltage from the fuse???
Car sat for a while and used to work. Had the *Rambo* Done on it, waterpump/chains/belts/etc. AC had been Converted over to new style and works amazingly!! AC Motor Works properly. Heater motor seems to have a problem.... Suggestions? Would a bad Motor Resistor cause it to cut off voltage/etc? |
