1984 944 Battery problems
Ok here goes I got my porshe 76,oookms
It runs strong and fast int good panit is faded but body is great. Now the nightmare Put new alt,Battery and Positve-Negative cables on it however never replaced the ground for motor seems not bad. I replaced the relay for light motor because it was not folding down sometimes minutes later it would that never hellped thurgh. Basicly u drive during the day its fine till moring battery is dead in the moring or if u hit lights at night kills battery after hour driving. so iam stumped other problems are sunroof wont work going check relays on that for motor. I replaced all fuses in fuse box but not the relays .I notice the wipers come on sometime as well when u use turn signal. I also took the deck out for the stereo because this was wired wrong . I know he put an after market front clip on it so i will check the wiring there next . If anyone has had this these problem hit me up |
RE: 1984 944 Battery problems
Take the alternator and have it checked,you could have gotten a bad one or it could be the wrong alternator or even hooked up backwards.
| All times are GMT -5. The time now is 08:18 AM. |
