-   -   battery problem?? (https://www.germanautoforums.com/forum/porsche-944-9/battery-problem-7198/)
dm84944 Dec 2, 2008 12:03 AM
battery problem??
i have a 84 944 and my serpentine belt always squeaks.. i have bought a new one a couple times and it works for a couple weeks maybe and if i spray it with "belt conditioner" itll be ok for a whilebut itll start up agian.. especially if its night time (when my lights are on and theres more electric pull) but it has a new alternater so i dont know if it could be the battery or something. any suggestions would be appreciated thanks
951jamie Dec 2, 2008 07:17 AM
RE: battery problem??
Sounds like the belt is becoming loose.Check to make sure the bolts that mount the AC compressor have not come loose or fallen out.Then readjust the belt.On the 944 if they are the least bit loose they will squeal!!
jamie@944online.com
dm84944 Dec 2, 2008 05:29 PM
yea i remember noticing the ac compressor bolt was missing before, its possible it fell out/ got loose again thanks a lot
Fast951 Dec 3, 2008 06:56 AM
Use Loc-Tite red or some other type of thread locker to help the bolt(s) stay in. Addition of a German type wavy washer on the bolts could also help. Don't over-tighten.
PorscheDoc Dec 3, 2008 10:29 AM
If you use loctite, use blue. Red is a real pain to break lose if you need to, without using a torch. But if everything is installed correctly, you should never have to use loctite.
