Bleeding coolant
Old Feb 26, 2008 | 06:42 AM
Skywalker's Avatar
Default Bleeding coolant
Hi guys, what is the correct procedure for filling and bleeding the coolant system on a 944? Do I need to raise the car or anything? Cheers
Old Feb 26, 2008 | 08:08 AM
Default RE: Bleeding coolant
You don't need to raise it, but it does help if the car is parked slightly uphill. Start the engine with the coolant tank cap removed. Fill coolant until it stops taking it. Let the car warm up. Once the car starts to get near operating temp, crack the bleeder nipple on the coolant neck (early 83's still have the coolant bleeder on the upper radiator hose if it has not been updated), air should come out. Close the bleeder. Let the car run for awhile, and repeat. Sometimes the early cars can be a real pain to bleed. Often if the bleed screw doesn't get all the air out, I will let the car sit and cool down overnight, which usually will burb a bunch of air out, and you can just add coolant in the morning, and give it a quick bleed and you are done.
Old Mar 3, 2008 | 01:15 PM
tgooke's Avatar
i'm sorry but where is the coolant neck
Old Mar 3, 2008 | 02:58 PM
Comes right off the top of the head where the upper radiator hose attaches.
NONNIEMYERS
Jun 14, 2010 07:04 PM
vette1
Sep 28, 2008 10:14 AM
Acadist
Sep 27, 2008 08:42 PM
ryan 944
Mar 16, 2008 12:22 PM
riverdogs
May 20, 2007 10:55 AM
