-   -   engine rebuild (https://www.germanautoforums.com/forum/porsche-944-9/engine-rebuild-2577/)
bad2th3bone86 Dec 30, 2006 02:28 PM
engine rebuild
Hi there i have recentyl just picked up a 1986 944. I am new to the porsche world so i hope you guys can help me out a bit. I am looking to see how much an engine rebuild kit would cost me. The motor has 215000 on the odometer so i think it is time for a rebuild. It also leaks oil. Any kind of input is greatly appreciated!:)
PorscheDoc Dec 30, 2006 08:09 PM
RE: engine rebuild
Plan on about $2500-3000 for all the parts you will need to rebuild an engine.
Things you will need:
Rod bearings
Main bearings
Piston rings
Valve seals and guides
Crankcase gasket set
Head gasket set
Waterpump
Timing belt, balance shaft belt, alternator, and power steering belts
All rollers for T&B belts
Front engine seal kit
Camshaft bolt
Loctite 574 (50ml minimum)
Various coolant hoses depending on what needs to be replaced.
kinderrich Dec 30, 2006 08:49 PM
RE: engine rebuild
You may want to drive it as is for a while and see if you can find a low mileage used engine. While it is fun to rebuild these engines, the aluminuim block can add alot of cost if it needs any work.
