fuel line
so my leak upon further inspection my fuel leak is alot worse than origonally thaut, and also the leak is on the highpreasure side not the return side, i want to have the line repaired as it seems to be the fitting at the regulater thats leaking. not an actaul hole in the line but there doesent seem to be a way to remove the rubber section, its all one piece, any ideas?
[IMG]local://upfiles/3978/32B193EB4909417EA0CF6EE820DC5526.jpg[/IMG]
Not sure if this will help, but Lindsey Racing offers an option. Check out this link: http://www.lindseyracing.com/mm5/mer...=944FUELLLINES
You need to remove that crimp off the hardline, and the hose will come off. I would pull the fuel pump fuse, start the car, wait for it to run out of gas, then let it sit for a few hours, then carefully cut off the crimp.
sdeuroperformance
Aug 11, 2008 02:53 PM
