fuel pump need help
I ordered a new fuel pump for my 87 turbo and it is about 1/2 the diameter of the one I am replacing. I am sure it is the right part number but not sure if it is the right part - has anyone else ever changed their pump and if so did you have the same experience? I am not sure if I should put it on or not - the local dealer was no help.....
I have already replaced the filter and the fuel pressure regulator hoping the pump is the reason it won't start. |
RE: fuel pump need help
Stupid question, but did you replace the dme relay before questioning the pump working or not? Every pump i have replaced has been the same, but maybe the incorrect pump was in there to start with....or an aftermarket pump.
yes I did replace the DME, forgot to mention it. thanks
| All times are GMT -5. The time now is 09:53 AM. |
