Gas leaking onto block...
Hey all;
Last week I noticed that one injector was leaking (bottom). Suspecting a seal problem even though they have all been recently replaced, I picked up some seals. Today I removed the rail and inspected the old seals. They seem fine. I replaced the one I suspected and reinstalled the rail etc. Now two injectors are leaking. Where did I go wrong? Did I not seat the injectors properly? Thank you. speedy |
Hard to say without seeing it in person. Fuel rails are also known for cracking and leaking.
The fuel rail is fine. One would suspect seals and o rings. I know it's always good to replace all of them once the injectors are out. I only had 2 new seals and was looking for a quick fix to get the car to somewhere where I could work on it more easily. The fact that two injectors are now leaking makes me wonder if I damaged them re installing the rail? Stupid question but if the rail is on and tight, the injectors must be in all the way...am I wrong?
R. |
Well if the seals are nicked or shrunk, then it is going to leak under 40psi pressure.
