Heater Problem
I know youve probably seen this problem before but...my car has just recently been blowing only hot air, especially at higher speeds/revs like on the freeway.Even when the vents are shut and theair is off, hot air still seeps in! SoI talked briefly w/ a friend at Brumos (local Porsche Dealership) and it may be a plastic clip on the heater control unit (He gave me a small plastic plug/clip).Just wondering where it is and if there are any other possible problem areas...Thanks in advance!
~James |
RE: Heater Problem
Look down on the side of the unit (drivers side footwell)
RE: Heater Problem
Thank ya kindly Doc! Hopefully that will fix it...
RE: Heater Problem
when you say plastic clip are you talking about the tempature potentiometer that controls wether it blows hot or cold air? I'm having the same problem but I just need a new heater valve.
RE: Heater Problem
Yeah thats exactly what I was talking about...sadly that didnt fix it so I guess it could be the heater valve or something else...
RE: Heater Problem
Check to make sure the vacuum line is connected to the heater control valve and the firewall.
RE: Heater Problem
I ahve the same problem...waht happened to the other thread?
