-   -   how should my '86 944 shift? (https://www.germanautoforums.com/forum/porsche-944-9/how-should-my-86-944-shift-7908/)
dave1986944 Apr 19, 2009 07:44 PM
maybe this is crazy question but I'd sure apprecate any comments from fellow owners - When I shift in pretty much any gear, I can 'feel' the gears a bit, even if the clutch is fully depressed. I am new to these cars. Is this normal? I know it improves some at higher speeds; could I just not be revving this enough or what? Had clutch done when I got this car - it di need replacing. Shop that did the work (very good rep) has said operation of new clutch is A-ok i.e., normal. I guess I am asking how smooth shoud I expect shifting on this car to be. Thanks to all - appreciate it.
PorscheDoc Apr 20, 2009 03:52 PM
Have you tried changing gear lube yet?
dave1986944 Apr 20, 2009 06:17 PM
nope.
guess, I'll look into that ASAP. Right now have no idea what that may involve but the Hanes is handy...thanks for your comments.
dave1986944 Apr 20, 2009 06:35 PM
does trans oil get replaced in process of doing a clutch?
if so I should be good there.. I can check for adequate level though.
Hammer Apr 20, 2009 07:30 PM
Hi
I found that if you hesitate between gears, that the tranny seems to respond better.
Paul
