-   -   Oil Filler Gasket (https://www.germanautoforums.com/forum/porsche-944-9/oil-filler-gasket-6883/)
Rob944 Oct 3, 2008 07:00 AM
Oil Filler Gasket
I have a leak! It seems to be coming from base the oil filler cooler where it meets the block. (that is where most of the oil has collected). Is there a gasket there that may need to be replaced? Is this a common point of failure?
thanks!
PorscheDoc Oct 6, 2008 08:01 AM
RE: Oil Filler Gasket
There are 2 o rings on the oil air seperator that need to be replaced. Also check the rear balance shaft cover while you are in there.
