PorscheDoc I need your help!
3 Attachment(s)
My 944 recently quit running and I have pin pointed it down to a weak coil and a bad relay. I need to know where I can find this relay, I have looked at Auto Part stores and have been unsuccessful. Any advice or suggestions would be greatly appreciated. Here is a photo of the relay.
Attachment 1711 Attachment 1712 Attachment 1713 |
RE: PorscheDoc I need your help!
It is a $10 relay, I can get you one if you need it. What slot did you pull it from?
If I remember correctly I pulled it from the #20 slot but I'd have to double check to make sure. If you could get me that I would be very appreciative. The coil is putting out low voltage also, how much do you think you could get me a coil for? Thank you so much
