power seats not working
Hi all
Can anybody tell me how to diagnose the problem with the power seat in an 86? The rear motors/ swtich works, however the front does nothing. No clicks, no noise, nothing. So I'm not sure if the problem is the switch or the motor. Also is there a manual adjustment for this. I just need to lower the seat somehow. Also, any ideas on fixing and diagnosing a door light switch? THe ligths both work, but do not come on when the driver side is opened, they only work wit the passenger side door. Thanks. [align=left] [/align] |
RE: power seats not working
Put 12 volt power to the motors directly and see if they move. If they do, then it is your switch (most likely). Rarely do I see motors fail.
For the door switch, I would replace the little contact switch. |
Hi again
I still have not had a chance to look at the seats, but I do know that the door switch is not the problem with the interior lights. What else should I consider. I'll probably not worry about this too much more, its really minor. Anyways.. thanks.. Garren [align=left] [/align] |
