power steering
thinking about putting power steering in my 86 944n/a, does anyone know any tutorials or how to's of doing this?
any help would be great. thanks Dave |
RE: power steering
It doesn't already have power steering? That was standard by 86. Someone must have removed it. If the mounting bracket for the pump is still there, then it came with PS (as it should have). You would need the entire long rack, steering shaft, pump, PS pulley, and all the lines. Running them is fairly self explanatory. You will have to pull the front bumper to install the return cooling line.
RE: power steering
its an 83' sorry.
no power steering is really no good when around the center of town, or short trips |
RE: power steering
I actually pulled the power steering out of my car and put in a manual rack. Already sold all the parts though....
RE: power steering
Ok, if it is an 83, then it will not have the power steering mount, which is also the front lower balance shaft cover assembly. You will need to source that as well.
RE: power steering
so what am i looking at for $$ if i do it myself... and is it worth it?
RE: power steering
I dont think it is worth the money personally: The only way it will ever be a leak free system, is if you buy a reman or new rack, don't buy a used rack, they usually leak.
$300-400 for a rack (reman) $50-100 for the pump (used) $15-20 for a used reservoir $160 for the return line (the line is a major PITA to replace, so put a new one in) $35 for the reservoir to pump line $50 for the other line (return line to reservoir, on the rack end) used. $50-100 for the front balance shaft cover/PS mount $30 for a new balance shaft sleeve $15 for the new balance shaft wiper seal and mylar seal $10-15 for a used PS pulley that goes on the crankshaft. $150 for a new intermediate steering shaft If you can find someone who wants to go to a manual rack, you could easily work a trade for all of their components, for all of yours. A good manual rack with good tie rod ends and steering shaft will bring 350-400, so it is a fair trade. |
