-   -   water pump bolt broken (https://www.germanautoforums.com/forum/porsche-944-9/water-pump-bolt-broken-5358/)
kinderrich Mar 2, 2008 10:34 AM
Replacing the water pump on an 86 NA two of the bolts broke off. I got one out , but had to drill the other. Is it better to use a heli coil, or just tap the hole for a bigger bolt? This bolt is the inside/top bolton the water inlet.
PorscheDoc Mar 2, 2008 11:06 AM
RE: water pump bolt broken
I would actually use a time sert, it will hold much better. Keep the size the same.
kinderrich Mar 2, 2008 03:29 PM
That seems to be best, I see a distributer in Texas, but not exactly clear how to order a kit. Is there some where on-line to get these. I am in Oklahoma City, but dont see any local vendors. Where do you buy them?
