Conversion of OST to PST
OST to PST conversion is an advanced email conversion software and facilitates its users an easy conversion of OST files into accessible Microsoft Outlook PST format. The software exports all OST file items into PST format with all email properties. The software recovers all email data from damaged OST file and provides option to save all recovered files into PST, EML, MSG and DBX format. Get more info click here:- OST to PST Conversion Tool to Export / Migrate Offline OST to Outlook PST File
https://lh6.googleusercontent.com/-e...YjllNjZjNw.png |
Exchange OST recovery tool is an efficient and reliable application to convert OST to PST file. This tool converts all OST items and saves in new PST file, including EML, MSG, RTF, MBOX, HTML, IMAP and PDF formats. It effectively restores emails, attachments, contacts, calendar items, notes, posts, appointments, etc. Through the software, users can easily fix the OST file errors and export to suitable format.
See more :- http://www.exchange.ostrecovery.org/ |
If you want to access OST file at the place where PST file is used by Outlook email client application then you have to change the file format from OST to PST first. So here is smart solution of OST to PST Conversion which will change your file format of OST file into PST format. Learn more about smart OST to PST Converter using the link: Export OST to PST | Smart OST to PST Converter Tool
Hi,
Try this tool which successfully exports OST file into PST format in few moments without losing any single bit of data. It is most recommended solution to convert OST file into PST format. For more info: - https://gallery.technet.microsoft.co...tlook-e1ea9bb0 |
Outlook PST file may gets corrupted due some reasons like virus attack, improper system shutdown, oversize file, software failure,etc. Resolving this type of corruption issues, either use manual solution or use third party tool. Both method smartly access Outlook PST file with whole PST file folders and It’s provide the best solution that effectively repair PST file data without any error messages. But I suggest you first try the manual solution.
Read more information, here:- How to Repair PST File with scanpst.exe? |
Export complete OST database items into PST file format with complete mailbox items including, EMLX, MSG, HTML, MBOX, EML, vCARD, vCAL and Outlook Profile.
For more info: OST to PST Converter Tool to Recover, Export & Convert OST to PST |
As you know OST file is restricted and cannot be accessed outside of its original MAPI profile. It means you need to log in with the original MAPI profile in order to open OST file. You can use Softkaen OST to PST Converter for accessing corrupt OST files.
