2000 Boxter-Check engine light problem
Hi,
I have a 2000 Boxter. The check engine light comes on with code PO455 which is "Evaporative Emission Control system leak detected(gross leak). I tried refilling the gas tank to full and making sure the gas cap is tight. Does anyone know how to fix or what the actual problem might be? Thanks, WC |
RE: 2000 Boxter-Check engine light problem
May need a new gas cap, maybe the seal is shot? Cheapest place to start.
Gas, Oil, Coolant Cap is probably loose.
