-   -   Boxster 2001 Brake Lights not working (https://www.germanautoforums.com/forum/porsche-boxster-11/boxster-2001-brake-lights-not-working-7236/)
asz88 Dec 11, 2008 02:38 AM
HI i have boxster 2 2001 - all brake lights not working suddenly - bulbs replaced and fuse ok.
Any suggestions - could it be the brake switch in which case how should i check and fix
Thanks
John
PorscheDoc Dec 11, 2008 10:32 AM
RE: Boxster 2001 Brake Lights not working
Brake light switch is probably bad. Only takes a few minutes to change and is about 20 bucks. Locate the brown/black switch down by the brake pedal (it has a plunger on it), and twist it 90 degrees then remove it. Pull off the electrical connector and then replace with new.
asz88 Dec 12, 2008 08:08 PM
Thanks so much DOC
Worked perfectly and all up only cost me $26 AUD.
Cheers
