Boxster Coolant overflow/leak
I am having a problem with the Coolant periodically leaking out and then it stops. Did a leak check and nothing. Anyone have this problem before?
RE: Boxster Coolant overflow/leak
There is an updated radiator cap that is recommended for the boxster. The old one does have problems. The coolant tanks are also prone to cracking, but if you coolant level is fine, then it is probably ok.
| All times are GMT -5. The time now is 08:16 AM. |
