Check engine light
Hi everone. First time here. My check engine light is not working (Po650). Already checked fuse. Any ideas?
RE: Check engine light
What do you mean your check engine light is not working? It should only come on if there is a problem.
How do you know it is not working? If it is not on, it means nothing wrong, right???
Thanks for the response! When I start the car all the lights come on for a secondexcept the check engine light. I can't pass smog until I fix it.
That's the thing. I had a few problems, but the light never came on. I went to smog the car and the guy told me I had a few engine codes come on, but the light wasn't working. Could it be a burned out bulb? Any ideas would be great.
