Coolant Warning Light
Hi Guys,
Just recently had my water pump replaced on my '99 Boxster. The car runs great, doesn't overheat, but... the coolant warning light continues to blink, especially at first start up of the day, and sometimes at the end of the day. It will go off during the day and at different intervals... Is there something that needs to be reset? Is it something I can do myself, or do I need to take it back in to the shop? Thanks, Cliff |
RE: Coolant Warning Light
You are probably low on coolant. There was probably an air bubble in the system when they filled it. Take it back to the shop and tell them to look at it since they were just in there.
HI SPOOEY- DON'T KNOW ABOUT YOUR WARNING LIGHT PROBLEM BUT I AM REPORTING TO YOU THAT PORSCHE DR. ADVICE ON THE WINDOW PROBLEM WAS RIGHT ON THE MONEY. JUST REMOVE THE MICROSWITCH AND READJUST IT. WORKED FINE FOR ME. GOODLUCK, BOB
