Engine Light? 4 U GURU'S
Old Aug 5, 2004 | 06:00 PM
Porscheneer's Avatar
Default Engine Light? 4 U GURU'S
I Just boughta boxster it has 52 K on it it just came back from the 60K service that I had done early and they said the car is fine however this check engine light keeps comming on
so my questions to the GURU's does it turn off on its own after a while ?
Why is this happening?
is it a sensor ?
is this a problem or quirk for this model and milage?
Please help a fellow Porschster!
Jay
Old Nov 15, 2004 | 07:32 PM
jmancool's Avatar
Default RE: Engine Light? 4 U GURU'S
Hello Jay
If a warning light comes on (check engine) that means you have a problem. It most likley a sensor problem but the only way to find out is to take it to a Porsche workshop ASAP before it does anymore damage.
Good luck
Old Jan 15, 2006 | 12:14 AM
leeclanual's Avatar
I would take it back to the dealership that serviced your car... probably just a loose connection causing a vacuum type leak. Don't drive it if the lights blinking... steady is OK.
RICFLYNN
May 11, 2008 03:51 AM
is2002
Jun 17, 2005 06:29 PM
eneale
Jun 16, 2005 10:22 AM
brfran
Nov 6, 2004 08:42 AM
bjporsche
Jun 10, 2004 09:57 PM
