-   -   Engine Light? 4 U GURU'S (https://www.germanautoforums.com/forum/porsche-boxster-11/engine-light-4-u-gurus-187/)
Porscheneer Aug 5, 2004 06:00 PM
I Just boughta boxster it has 52 K on it it just came back from the 60K service that I had done early and they said the car is fine however this check engine light keeps comming on
so my questions to the GURU's does it turn off on its own after a while ?
Why is this happening?
is it a sensor ?
is this a problem or quirk for this model and milage?
Please help a fellow Porschster!
Jay
jmancool Nov 15, 2004 07:32 PM
RE: Engine Light? 4 U GURU'S
Hello Jay
If a warning light comes on (check engine) that means you have a problem. It most likley a sensor problem but the only way to find out is to take it to a Porsche workshop ASAP before it does anymore damage.
Good luck
leeclanual Jan 15, 2006 12:14 AM
I would take it back to the dealership that serviced your car... probably just a loose connection causing a vacuum type leak. Don't drive it if the lights blinking... steady is OK.
