Mass Air Flow Sensor
In the service manual, replacing the MAS seems pretty straight forward, unplug it and plug in a new one. Once that is done, is there any kind of reprogramming required for proper operation or special equipment needed? Thanks in advance - rPm
RE: Mass Air Flow Sensor
Nope, just make sure you plug the electrical connector back on. Also, it has to face the direction that air is coming in, so make sure your orientation is correct.
