rear rotor issue
When i take the wheel off there are i believe 5 additional lugs, no problem except one. It's almost like a wheel lock but on the hub, and i don't have the key for it, does anyone know a trick to getting one of these off without having the key?
Pound a large 12 point socket on to the lug (i can't remember the size, 22mm or so, and then use a long breaker bar to slowly break it loose.
ok thanks I'll try that today, if that doesn't work is there any other options?
Well.....uh it does work, so that is your option.
