Recent DVD Navigation Installation
Old Mar 19, 2008 | 07:53 PM
trieullionaire's Avatar
Default Recent DVD Navigation Installation
I recently installed the Avic D3 Navigation with rear view camera in my 2000 Boxster. Still have a few interior upgrades to do but the navigation system install was a success and really made the interior look phenomenal and updated.
What was needed for the job:
T20 Torx Screwdriver
Phillips Screwdriver
A dremel with cutting wheel
A file to sand down rough edges
Electrical tape & Wiring Caps
Wire Stripper
Double Din Kit Includes:
Precision cut fascia (trim) piece in Piano Finish to match Pioneer System
Double Din Housing & Brackets
Double Din Custom Support Bracket for Porsche
Heat Shield, Complete Wiring Harnesses, Antenna Adapter & Radio Removal Keys
Some of the things I really like about my new system is that I know that the install is solid. One of the challenges I noticed other folks had was the weight of the system, and so they elected to have it sit low as possible on the dash. Using the custom support bracket to support the back end of the navigation, and also choosing to mount the double din housing as high up as possible, I was able to keep most of the gap below the system as oppose to the top. And to make sure my stereo stays relatively unaffected by the heat from the climate duct system, I installed a heat shield between the duct and navigation.
The other challenge was that most standard double din navigation systems are a lot smaller than the size of my boxster's opening, so regardless of what I install it was going to make the system appear smaller. Didn't like that look too much, so instead of trying to match up the fascia piece to my car, I went with the piano black fascia piece instead to match it up to the Pioneer system. I think going this route made the fascia piece look like its part of the stereo which gives the illusion that the system is a bit bigger.
Anyways, I posted some of the pics below for everyone to check out!
[IMG]local://upfiles/6052/9D259CC6BF4D40DE88738E8F016C3386.jpg[/IMG]
[IMG]local://upfiles/6052/165E3905F1394E39AA1A5B9F2D9E619E.jpg[/IMG]
[IMG]local://upfiles/6052/69C386BCB4D848329D501E8D09C3DE86.jpg[/IMG]
Old Mar 19, 2008 | 08:58 PM
cmilam's Avatar
Default RE: Recent DVD Navigation Installation
I have the same Nav system, but had mine installed. Nice job on your installation!
Old Mar 19, 2008 | 09:12 PM
Hey thanks mate! Hey could you post a pic of it or email it to me. I like to see it if you get a chance. Thanks!
Old Mar 20, 2008 | 01:39 PM
cmilam's Avatar
Sure, what is your email address?
Old Apr 5, 2008 | 10:16 PM
CloneTroop's Avatar
Wow that is gorgeous.
*DROOL*
Old Nov 4, 2008 | 04:51 PM
dvoelpel's Avatar
You did a fantastic job on your installation, and I appreciate the detailed summary. I bought a 2000 Boxster 10 days ago and have stopped in at a couple of audio shops locally to talk to the "experts" about upgrading the sytem to something similar to what you described. I'd like to add a unit with nav/bluetooth/iPhone connection.
I can find a unit that does all those things. But where did you buy your Double Din Installation Kit with the elements you described:
- Precision cut fascia (trim) piece in Piano Finish to match Pioneer System
- Double Din Housing & Brackets
- Double Din Custom Support Bracket for Porsche
- Heat Shield, Complete Wiring Harnesses, Antenna Adapter & Radio Removal Keys
I particularly like the fascia you used and would like to acquire the kit for my installer. Thanks a bunch.
Old Nov 15, 2008 | 02:30 PM
ESOTERIC's Avatar
very nice!
solomon24
Jun 16, 2014 08:40 PM
solomon24
Jun 16, 2014 05:36 AM
jimusa
May 23, 2010 02:09 PM
ACAPNZ
Mar 4, 2009 04:24 PM
drleahy
Feb 3, 2006 04:18 PM
