Recent DVD Navigation Installation
I recently installed the Avic D3 Navigation with rear view camera in my 2000 Boxster. Still have a few interior upgrades to do but the navigation system install was a success and really made the interior look phenomenal and updated.
What was needed for the job: T20 Torx Screwdriver Phillips Screwdriver A dremel with cutting wheel A file to sand down rough edges Electrical tape & Wiring Caps Wire Stripper Double Din Kit Includes: Precision cut fascia (trim) piece in Piano Finish to match Pioneer System Double Din Housing & Brackets Double Din Custom Support Bracket for Porsche Heat Shield, Complete Wiring Harnesses, Antenna Adapter & Radio Removal Keys Some of the things I really like about my new system is that I know that the install is solid. One of the challenges I noticed other folks had was the weight of the system, and so they elected to have it sit low as possible on the dash. Using the custom support bracket to support the back end of the navigation, and also choosing to mount the double din housing as high up as possible, I was able to keep most of the gap below the system as oppose to the top. And to make sure my stereo stays relatively unaffected by the heat from the climate duct system, I installed a heat shield between the duct and navigation. The other challenge was that most standard double din navigation systems are a lot smaller than the size of my boxster's opening, so regardless of what I install it was going to make the system appear smaller. Didn't like that look too much, so instead of trying to match up the fascia piece to my car, I went with the piano black fascia piece instead to match it up to the Pioneer system. I think going this route made the fascia piece look like its part of the stereo which gives the illusion that the system is a bit bigger. Anyways, I posted some of the pics below for everyone to check out! [IMG]local://upfiles/6052/9D259CC6BF4D40DE88738E8F016C3386.jpg[/IMG] [IMG]local://upfiles/6052/165E3905F1394E39AA1A5B9F2D9E619E.jpg[/IMG] [IMG]local://upfiles/6052/69C386BCB4D848329D501E8D09C3DE86.jpg[/IMG] |
RE: Recent DVD Navigation Installation
I have the same Nav system, but had mine installed. Nice job on your installation!
Hey thanks mate! Hey could you post a pic of it or email it to me. I like to see it if you get a chance. Thanks!
Sure, what is your email address?
Wow that is gorgeous.
*DROOL* |
You did a fantastic job on your installation, and I appreciate the detailed summary. I bought a 2000 Boxster 10 days ago and have stopped in at a couple of audio shops locally to talk to the "experts" about upgrading the sytem to something similar to what you described. I'd like to add a unit with nav/bluetooth/iPhone connection.
I can find a unit that does all those things. But where did you buy your Double Din Installation Kit with the elements you described: - Precision cut fascia (trim) piece in Piano Finish to match Pioneer System - Double Din Housing & Brackets - Double Din Custom Support Bracket for Porsche - Heat Shield, Complete Wiring Harnesses, Antenna Adapter & Radio Removal Keys I particularly like the fascia you used and would like to acquire the kit for my installer. Thanks a bunch. |
very nice!
| All times are GMT -5. The time now is 02:53 AM. |
