Secondary air injection system
My 2000 Boxsters' CEL is on, fault code P1411 (secondary air injection system). My question is, will it cause additional damage if I drive the car to the dealer or should I have it towed? Car seems to run fine but has slight surging at idle. Many thanks - rPm
You can drive it just fine. More than likely a vacuum leak problem.
Porsche Doc,
Thanks for the reply, you have helped me previously and I always feel reassured when I read your replies, to me or someone else. Is there a more substanial way to thank you? Thanks again for your help - rPm |
Always glad to help :)
