View the engine
this is for porsche doc if it would be possible that you would be able to send me pictures and instructions as to how to remove interior components to view the engine it would be greatly appreciated thanx
RE: View the engine
www.turbo911.com I have a writeup in the "How to" section. Look for boxster serpentine belt replacement, and the first part of that will guide you through most of the way. Once you get the top carpet section out, just unlatch the 5 brass looking tabs, and pull the metal cover off (that part isn't in the write up, because you don't need to go in that far for the serpentine belt).
RE: View the engine
thanx alot u have been alot of help
RE: View the engine
Not a problem :) If you get stuck, just give me a hollar. I am currently out of town for the weekend, so I am not checking the forums quite as often as I usually do, but I will get back asap.
