Window Issue
Passenger side window fails to lower (1/2 inch) when opening the door and therefore causes impact with edge of top during opening ( and of course during closing as well). Raises and lowers during all other times. When I click door handle I can easily push the window down the 1/2 inch to keep it from impacting.
Any quick solutions other than replacing the window motor or regulator??
Does it fail when opening from the inside, or from the outside? If from the outside, then you need to replace the door latch mechanism. I have a post on my blog that explains the window drop failures.
AaronStark
Mar 17, 2006 08:22 PM
BradS911
May 17, 2005 06:08 PM
