-   Porsche Cayenne (https://www.germanautoforums.com/forum/porsche-cayenne-10/)
-   -   2009 cayenne turbo s, water in headlight assembly, faulty control unit (https://www.germanautoforums.com/forum/porsche-cayenne-10/2009-cayenne-turbo-s-water-headlight-assembly-faulty-control-unit-15258/)
joko Jul 28, 2017 03:15 PM
This weekend I discovered water inside the driver side headlight assembly. I also received a system fault warning on the dash. Inspection of the headlight assembly revealed no cracks or defects, so how did the water enter? Now I am told I need to replace the control unit on both sides otherwise they will not work properly. Before I do this I would appreciate any input regarding similar experiences or suggestion on where the water may have entered. I do not want to make this expensive repair only to have the problem recur. Thanks
Pepperman Feb 16, 2019 01:27 PM
I had that same problem! I put selicone around the edges no more H2O ! But water went in ballast and bulb but still having problems now wipers not Working! Should of buy a FORD🤬
