convert outlook to lotus notes
Old 07-10-2014, 05:21 AM
NicholasGonzalez's Avatar
Default convert outlook to lotus notes
Often, professionals and home users working with Lotus Notes email client need to migrate their emails to MS Outlook platform. As, Lotus Notes create .NSF file whereas MS Outlook create .PST file and both of them have their unique features and they are not compatible to each other. In many cases, MS Outlook is better than Lotus Notes. Advanced features of MS Outlook attract Lotus Notes users for NSF to PST converter tool.
Converts the Lotus Notes file (*.nsf) into an Outlook (*.pst) file . You can directly import the converted PST files into Microsoft Outlook and access all
your emails and other components, including Attachments, Contacts, Calendar Entries, and Journals etc.Provides option to save the converted mail items folder as MSG, PST or EML files.
The software either saves the converted mail items in a new PST file or appends them to an existing one.The Software is capable to automatically locate your NSF file, or if you want to select any other file, you can select any local or server mail file for export. Once this Software creates the PST folder, you may export directly to Outlook or choose to export to a sub folder.
Quick Recovery's unique Guided File Excavation Technology (GFETCh) helps in locating email files and folders.his is the best NSF to PST Conversion Software. The Software supports to convert Mails, Address Books & Calendar of NSF files.NSF to PST Converter keeps the format intact even after migration.
It takes care of TEXT, HTML or RTF formats when saving. User can choose from a specific date range and decide to include/exclude “All documents” folder from Lotus Notes to Outlook. They can also save these files in .MSG
and .EML file formats, in addition to the above mentioned file format. The software supports UNICODE conversion as well and comes with free trial edition.
So See More Info About This Software: http://www.recoverfilesdownload.com/nsf-to-pst-converter.html
Old 08-25-2014, 02:03 AM
SamuelJones's Avatar
Try NST to PST Converter software and convert Lotus Notes (.NSF) files to importable MS Outlook (.PST) files. This tool easily migrate from Lotus Notes to MS Outlook by exporting all your emails, contacts, attachments, journals, etc to Outlook PST file. For more information and free download click :- http://www.nsf-to-pst-converter.reco...etedfiles.com/
Old 08-26-2014, 11:50 PM
kenkraus's Avatar
Few months back i had used ths tool for Lotus notes to outlook migration, i had completed this task with few minutes.
Use Free trial version to see the preview of converted Lotus Notes Mailboxes.
So Try:- http://www.filesrecoverytool.com/nsf-to-pst-converter.html
Old 09-05-2014, 02:19 AM
Ronal Dimaro's Avatar
Easy to use and risk free email migration tool is available to quick convert Outlook to Lotus Notes, Go to http://www.exportpsttonsf.net for free download tool to trial, Kernel for PST to NSF software which make easy migration from outlook to notes.
Old 09-06-2014, 04:41 AM
abelmartin002's Avatar
I would like to suggest you another good NSF to PST converter tool that is specialized for migration NSF file to PST file format. Get more details see here: http://recoverydatatools.com/nsf-to-pst-converter.html
Old 10-09-2014, 06:00 AM
CharlieDoerr's Avatar
If you want to recover your Lotus Notes emails into Windows Outlook, then you should take a help of a NSF to PST Converter software for a best result.I would like to refer such a tool :- http://www.tools4recovery.com/nsf-to-pst-converter.html
Old 10-14-2014, 11:49 PM
jamesheideman's Avatar
There are various professional software available, by which you can instantly convert Lotus Notes emails to Outlook (NST to PST). I would like to suggest you such a perfect software NSF to PST Converter. You can check out this tool along with a free trial from here :- NSF to PST Converter – Migrate Lotus Notes (NSF) Emails to Outlook PST
Old 11-03-2014, 12:17 AM
NST to PST Converter is an efficient tool for converting Lotus Notes (.NSF) files to importable MS Outlook (.PST) files. The tool has instructive user interface that guides you throughout the conversion process. In this way, you can easily migrate from Lotus Notes to MS Outlook by exporting all your emails, contacts, attachments, journals, etc to Outlook PST file. For more information and free download click:- Lotus Notes NSF to PST Converter Software
Old 12-20-2014, 04:36 AM
Lotus Notes to MS Outlook converter utility instantly move the entire NSF file to PST file format. It has easy-to-use program and its functionality makes you flawlessly, effortlessly to convert NSF to PST file correctly. For more details see here: Convert NSF to PST - NSF to PST converter to convert Lotus Notes file to Outlook PST file format and also visit this post Lotus Notes to MS Outlook Conversion Software to know more this utility
  #10
Old 09-28-2016, 11:01 PM
radissonblu's Avatar
Default Convert NSF file to PST file
fsfafafasfa
Quick Reply: convert outlook to lotus notes
