emilytaylor |
04-25-2022 04:25 PM |
Is there any easy way to fix the QuickBooks balance sheet out of balance error?
To fix a balance sheet that is out of balance, take a backup of the company file and try to run the report in an accrual basis:
- In QuickBooks, go to the Reports menu and choose Company & Financial.
- Select Balance Sheet Summary and click Customize Report.
- Select the Display menu, go to the Report Basis and choose Accrual.
If your QB balance sheet is out on an accrual basis, the company file is damaged, and you need to rebuild it first. If the balance sheet is out in cash:
- Identify the date when the balance sheet went out, then find the transaction that makes the balance sheet out of balance.
- Change the date of the transaction. If it doesn’t work, delete and enter the transaction again.
If you need direct consultation on the ‘QuickBooks balance sheet out of balance’ issue, dial +1-800-579-9430and connect with certified QuickBooks professionals.
Read more:-
QuickBooks error 6073
Quickbooks administrator permission needed
Quickbooks condense data error
Quickbooks error OL 222
