Boxster mechanical
hello new here. i just have a question. just purchased 99 Boxster with 140K and when I stsrt it 1 out of five times it makes a whineing noise similiar to a starter bendix not connecting or a bad bearing. It does not happen all the time but on occasion. could this be the starter or some other common problem? Suggestions appreciated. car is Manual 5 speed
Thanks
Thanks
Hi to all,
Apart from worn out gears in the transmission, there could be faults with the bearings in the car. Bearings are located all over the car, and a damaged one could be the cause of a whining noise from the engine. So you want to have these checked, especially your alternator, water and power steering pumps.
williamsonsnina
Apr 8, 2021 03:44 AM
a4russianred
Mar 17, 2008 07:50 PM
