| PorscheDoc |
Jan 12, 2009 10:38 AM |
RE: timing belt-valves
Yes, the valves in the head are going to be bent if it broke the timing belt. There are 8 valves in the head, and you can typically bet that 4 of them will be bent at least. You won't know if they are the intakes or the exhausts until you pull the head. I would plan on installing new valve guides and seals while you have the head off. Get it trued up, new valves installed, and put it back together. You should be doing the rollers and waterpump and new belts when you put it back together so you don't have this problem again. Figure anywhere from $500-750 doing the work yourself.
