BMW M3 review
Old Mar 27, 2008 | 10:40 AM
Hot911TT's Avatar
Default BMW M3 review
Not a great review on the M3...not even close to the 911, again no comparison.
An all-new BMW M3; it doesn’t happen very often - around every seven years or so. And with the arrival comes expectation, and lots of it. This is the car that has repeatedly redefined what a ‘small’ sports saloon should be. But this time it’s different again. Not least, the switch to V8 power after two generations of the wonderful straight ‘six’ and a big increase in price – up to $65K. And there're talented rivals too - the Audi RS4 for example, not to mention the forthcoming C63 AMG. It still hasn't broken into the Porsche 991 GT class.
Still, you could wedge a RAF hangar door open with the BMW press pack handed out on the launch. The book devoted purely to the engine is a reference tome in itself, but then technology and lots of it is one of the new car’s principal weapons.
[/align]Of course, there’s that new hi-tech all-alloy 4.0 litre V8 featuring double-VANOS, individual throttle butterflies and producing 420hp with 295lb ft of torque at 3,900rpm. That’s a huge increase over the old ‘six’ and BMW are quick to point out that it weighs 15kg less than the old engine too.
Elsewhere there’s a carbon fibre roof, lightweight suspension, MDrive facility with different setting programmable into an M button on the steering wheel (a la M5) and (optional) electronic dampers with three different settings. For now, a six speed manual gearbox is the only transmission available although some form of semi-auto ‘box will follow. Despite their best efforts, the M guys admit the new car weighs slightly more than the old one. As for the looks, well, beauty is in the eye of the beholder. [:'(]
[/align]‘Is it any good though’, you’re thinking. The answer is yes, but not quite in the way you might be expecting.
Unsurprisingly, the new car is dominated by its engine. Even when you first sit in the car, you’re immediately struck by the ‘powerdome’ bonnet that seems much more prominent from behind the ‘wheel. The V8 starts with a cultured growl and settles to a respectable idle. Around town it is well-behaved, and apart from the sometime clunkiness of the transmission at low speed it’s all very effortless to drive. The ride seems very composed too, certainly more comfortable than the old car, although we won’t really know until we’ve driven it UK.
[/align]As soon as you press the accelerator a bit more however you can hear the voice of the new engine: a tight, V8 chord with a hint of muscle car from low to middling revs. Extend it further and it howls like a modern race car: a single, focused note that sadly doesn’t alter much in tone but just heightens in pitch. At this point, you’ve still got 3,000 rpm to go…
The final charge of the V8 towards its 8,300rpm is really quite a remarkable thing. This is where the power is truly ferocious. Up until now, the M3 can feel slightly constrained by its weight and what feels like a longish set of gear ratios, but once you’ve tapped into that final band you’re really flying and the noise the thing makes as it falls into the soft limiter is unforgettable.
[/align]So why is it that I miss the old straight ‘six’ – even though it was incapable of such powermeister heroics? Thing is, the V8 is just so so, well, sensible. It doesn’t rattle like the old straight six did at times; it doesn’t spit and crackle and sound as if it’s digesting its own internals on occasion, because frankly, it isn’t. It’s a new engine, operating with micro-millimetre precision against a strict computer leash, and no doubt in this original iteration well within its own limits, unlike the old stager. The outright anger inherent in the old car has vanished, and with it some of the urgency of purpose, the sharpness of throttle response – even with the new car in its most aggressive setting. It’s a question of character.
We hack across the mountains of southern Spain, making our way from the launch resort towards the Ascari Race track inland. On these roads the new M3 is punishingly, absorbingly, illegally fast. Imagine the old Spa circuit without the rain and you’re about there: long, gently curving downhill straights that stretch out into the distance followed by sweeping, plunging and rising compound curves. It’s mainly third and fourth gear stuff in this car and it’s in its element. The chassis feels ok. [:'(]
[/align]It’s when the road changes on the other side of the mountain that things aren’t quite so impressive. The road is tighter now, with more corners that are less predictable in their curvature and often blind. It exposes the new cars biggest flaw - the steering, something that was never the strong point of the previous car either. It’s light (even in ‘sport’ setting let alone ‘normal’) and after a numb region around the straight-ahead becomes very quick without building any reassuring weight. Most of all though it’s remote from what the wheels are doing. Consequently, on a twisting road such as this, you’re always circumspect about your turn-in speed and often find yourself steering in two chunks on the entry to a corner to try and inform yourself of what’s going on down at the tyres. Bottom line: it’s a competent sedanand quick, but you just know in a Porsche 911 you’d have a huge grin plastered all over your face on a road like this, and in the new M3, you just don’t…
[/align]It’s hard to comment too much on the brakes – They are average and it was said that every press car on the launch had upgraded brake pads, ostensibly to cope with the circuit work at the Ascari track – but they hauled the M3 down from big speeds on the road without drama.
Two positives stand out at the Ascari racetrack. Firstly, the straights give you the chance to extend the V8 right to the cut-out in a number of different gears and the resultant speeds are very impressive indeed. Secondly, with this much power the car can be pitched sideways and held there in a wanton drift (try that in a RS4) through a number of the slower corners – which is hilarious, although only when you’re not paying for the tyres. However, as a tool to whittle away at your lap time, the new M3 is a little less convincing. It’s the small, subtle stuff once again: the remote steering; the LSD that feels a little slower to react than the old car; the lack of razor aggression in the engines mid range. Altogether, they slightly but decisively blunt the experience in a playground such as this.
[/align]So, the new M3 is a good car. Its talents when viewed purely objectively make a formidable package. It’s more comfortable than the old car: rides better, has more room inside and is kitted out with the latest tech available – at a cost. Apart from a worrying thirst – test cars were returning around 11mpg according to their trip computers, although they were driven hard – the new V8 is smooth, refined and perfectly suited to everyday use, yet with crushing reserves of performance.
It seems certain that many M3 buyers will find this new car a superb companion and that any thoughts are in the distinct minority when they contain phrases about ‘steering feel’ and ‘driver feedback’. Such things increasingly have little value in a marketplace obsessed with power.
[/align]But instead of relinquishing the keys with that gripping, longing, sadness in my gut that you’d assume would be there having driven ‘the new M3’, I find myself oddly detached from it.
That there really is room for a ‘CSL’ is not in doubt and my bet is it won’t be long in coming from what was and wasn’t said on the launch. Whereas the old CSL required plenty of in-depth fettling to extract that extra edge from an already focused package, it seems the positioning of this new car leaves a much easier gap in which to place a hardcore version.
Contrived, maybe; an exciting prospect, definitely. But in the meantime, perhaps just a little of the M3 magic has been lost…
Old Mar 27, 2008 | 04:24 PM
cmilam's Avatar
Default RE: BMW M3 review
This one sounds a little better than the 550, but it looks hidious--yuk! Thanks for sharing since BMW550sport has made all this hype over the M3. I hope he goes out to buy 2 of them.
Old Mar 27, 2008 | 08:46 PM
Hot911TT's Avatar
Yeah it's not an attractive car. Have you seen the instrument cluster? The VW beetle has a better set up OMG...what was BMW thinking?
Old Mar 28, 2008 | 10:50 AM
cmilam's Avatar
It looks a little better from the back and front, not the side. Haven't seen the instrument cluster but heard it was sparse.
Old Mar 28, 2008 | 07:42 PM
Hot911TT's Avatar
It's a square box on wheels. It's ugly from all sides!!!!!!!!!!!!!!
jamesbates
Apr 6, 2014 02:20 AM
trev0006
Feb 21, 2009 12:10 PM
Hot911TT
Mar 27, 2008 04:31 PM
