camcover gasket leaking
Old Oct 15, 2007 | 12:13 PM
m3bud's Avatar
Default camcover gasket leaking
I have a 1986 na 944, camcover is leaking oil. how many gaskets are involed in replacing the camcover gasket,any tips or procedure for this jobon replacing the gasket would be appreciated.
Old Oct 16, 2007 | 07:45 AM
Default RE: camcover gasket leaking
You should reseal the entire cambox while you have it off. You will need the rear hippo gasket (rear cam cover), main cam cover gasket, front o ring, front spacer ring, front mylar seal, front wiper seal, and a new cheesehead bolt. Probably about $50-60 in gaskets. Also, if you haven't done your timing belt recently, now would be the time, since you will have it all apart.
Rob944
Oct 6, 2008 08:01 AM
tgooke
Mar 4, 2008 06:05 PM
Wakemedernurse
Sep 14, 2007 10:14 PM
guardsred944
Jan 12, 2006 12:59 PM
ichosun1i
Sep 1, 2005 12:01 AM
