944 wont start
My early 1985 944 wont start. no spark and no fuel pump operation.
I have 12v to the coil , cap and rotor good,wires good , coil checks out, fuses good, battery voltage 12.6v at coil. where do I go next? thanks |
DME relay, then speed and reference sensors and the DME. I assume the tach does not bounce when you crank the car.
Thanks Doc,
No tack bounce. How do I identify the dme relay? Is the dme relay located with the other relays above the fuse box? |
If it is an early 85, then it is under the dash on the top row of relays. Black square tall relay, also called the fuel pump relay.
