968 degrease remorse...
Old Jul 17, 2007 | 10:22 AM
meatmachineman's Avatar
Default 968 degrease remorse...
[:@]Here goes... My 95 968 was out of commission for a couple of weeks due to the compressor. I finally got it all put back together and drove it... flawless. An hour or two later, I popped the hood and made sure everything was OK. I noticed the engine was a bit dirty and decided to do a quick degreasing on it. I sprayed some cleaner on it, let it set for a couple minutes and hosed it off. After sopping up what water I could I admired the clean engine and got in to fire it up. It started but ran rough. I put it into gear and it ran worse... reverse was worse yet. I started pulling plug wires, dist cap, vacuum lines and every connector I could find to ensure they were dry. I drove it around for a while to no avail. 36 hours later... same thing but now it will not go into 4th gear (Auto trans). I've pulled my head out of my butt so I won't degrease again, but I became disoriented during my cranial-rectal inversion and need help getting my baby healthy again. Your help would soooo appreciated!!!
Old Jul 18, 2007 | 10:08 AM
Default RE: 968 degrease remorse...
I figured it out... I took the plug wires out for the second time and actually noticed water around one of the spark plugs this time. Soaked up the water and my baby is back!!!
searebo
Mar 28, 2006 06:49 PM
CTiggerPigglet
Oct 24, 2005 01:53 PM
porschegordon
Sep 11, 2005 11:16 AM
porschegordon
Sep 11, 2005 01:44 AM
texaskj
Nov 9, 2003 08:38 AM
