GAS FUMES
HAS ANYONE HAD THS PROBLEM WHEN I DRIVE MY 1984 944 STOP AND GET BACK IN I SMELL GAS FUMES ......
ANY SUGGESTIONS:) |
RE: GAS FUMES
How about checking for fuel leaks at the rail or lines first. These cars are known for going up in flames.
RE: GAS FUMES
Make sure there is no leaks. Some cars may leak on a certain angle so when you are going up hill it leaks a bit causing you to smell it but then when you look under, it looks like there is no leak (leaks only when you fill the tank up)
| All times are GMT -5. The time now is 11:40 PM. |
