low coolant
Old Nov 11, 2008 | 12:52 AM
chunrhim's Avatar
Default low coolant
I have a 99 carrera with about 45K miles on it. I noticed the coolan light started to blink and check the level and it was low. Filled the coolant about 2-3 weeks ago and yesterday the coolant light started to blink again so checked the level again and it was pretty much empty. Does anyone have any idea what the most common problem causing this problem would be? Would really appreciate the help, and is it safe to have an independent porsche mechanic work on major work on the cars? Is there a way to see if they are really knowledgeable about the cars? Thank you
Old Nov 11, 2008 | 02:51 PM
Default RE: low coolant
Have you seen any external leaks on the ground around the left rear tire. The coolant tanks are known for cracking on the very bottom, which will leave a puddle by the left rear tire. If there are no external leaks, then you better check your oil and make sure the coolant isn't getting into oil via a slipped cylinder liner or bad headgasket.
Old Nov 12, 2008 | 02:01 PM
chunrhim's Avatar
there is some fluid under the car next to the left rear tire. I think you are probably right. as always.
do you think an independent porsche mecahnic can fix the problem without problems? Should I take it to a dealer? Thank you.
Old Nov 12, 2008 | 09:54 PM
Any independent mechanic should be able to handle it. The tank is about $125 IIRC, and a few hours to put it in. I have heard some dealers will charge upwards of $800 to replace, so avoid if at all possible.
Old Nov 12, 2008 | 10:54 PM
chunrhim's Avatar
once again, thanks for the information. I really appreciate it.
goebels97
Nov 30, 2006 01:09 PM
spooey
Jul 19, 2006 04:43 PM
SleekCarrera
Jun 9, 2006 04:55 PM
alanp
Nov 21, 2005 10:26 AM
kevfran
Sep 11, 2005 09:47 AM
