NSF to PST Converter software
Old Nov 5, 2015 | 05:10 AM
kennycureton's Avatar
Banned
Default NSF to PST Converter software
NSF to PST Converter software is a perfect and quick migration utility which efficiently moves unlimited no of mailboxes from Lotus Notes to Outlook. You can securely move all your emails and other data Lotus Notes/NSF to MS Exchange Server/MS Outlook/pst files. Few months back i had used ths tool for Lotus notes to outlook migration, i had completed this task with few minutes. Use Free trial version to see the preview of converted Lotus Notes Mailboxes.
for more info:- Lotus Notes NSF to PST Converter Software
Old Feb 12, 2016 | 12:56 AM
Arban Delacruz's Avatar
Default NSF to PST converter
RecoveryFix for Lotus Notes to Outlook converter tool comes with advanced features thats make NSF to PST conversion process very easy. You can also download Free trial version of the tool from here: Lotus Notes to Exchange Tool to Convert Lotus Notes Domino to Exchange
Old Apr 25, 2016 | 05:17 AM
jsen's Avatar
Default NSF to PST Software
NSF to PST software is useful for conversion of Lotus Notes data completely into PST file format. It is the fastest tool provided by eSoftTools for immediately export NSF to Outlook. Here other conversion options are also given as NSF to PST like NSF to EML and MSG format. Software is designed with advanced techniques and more advanced features. After Lotus Notes NSF data conversion to MS Outlook, split PST file.
Read More
How to Convert NSF File to PST
Old Aug 12, 2016 | 06:05 AM
Rawatsonika4u's Avatar
Banned
If your Lotus Notes NSF file gets corrupted and you are searching a professional tool. But professional tool is not the only way to repair or convert NSF file data to PST format. You can also use a manual trick for repairing corrupted NSF file and convert the recover data into PST format. There are few manual tricks given in the below recommended blog post.
Source link:- Manually Perform NSF to PST Conversion.
You should first try the manual tricks shared in the above blog post before using any paid tool. There would be no need to purchase any such tool if the free manual tricks work for you.
Old Oct 8, 2016 | 06:27 AM
anialex's Avatar
Get this software to recover NSF file and convert NSF file into PST mailbox within seconds. Program nice for converting NSF file to PST, EML, MSG format with whole versions of Lotus Notes NSF and Outlook file.
Read More:
Lotus Notes File Converter Easy to Convert NSF to PST
Old Jul 21, 2017 | 02:12 AM
florencesofia216's Avatar
NSF to PST software is creating wonderful interface on all windows operating system to convert NSF to PST. NSF converter works for multiple convert, export, recover and many more without losing any data. NSF to PST converter support all lotus notes and save them into the PST, EML, MSG, vCard, HTML, EMLX, MBOX and CSV. get more details please click the link: NSF to PST | NSF Converter | NSF to PST Converter
Old Jul 26, 2017 | 02:39 AM
lucasdawson1984's Avatar
MS Outlook stores its data in PST format whereas Lotus Notes uses NSF format for the same. In order to convert NSF format into PST format we may use conversion tools like NSF to PST Converter.
There is a manual method as well for transferring Lotus notes data to MS Outlook, using Export/Import feature in Lotus Notes or MS Outlook, but this method is very complicated and becomes very tedious if large amount of data needs to to transferred.
Whereas using the converter is very easy, quick and precise. This conversion tool can even convert encrypted NSF files into PST files.
Some Of Its Salient features are:
# Convert NSF files in bulk
# Convert all data including calendar, tasks, contacts and emails.
# Keep original files intact
# Compatible with all Windows OS and all versions of MS Outlook and IBM Lotus Notes
To lern more about both the procedure, visit: https://sysinfotools.com/blog/how-to...to-pst-format/
Old Dec 23, 2017 | 05:27 AM
kanariyajoseph's Avatar
Old Jan 6, 2018 | 12:20 AM
Erasmus-Taylor's Avatar
Get this best and safe solution of NSF file converter that nicely export NSF PST file. Restore NSF file to PST, EML and MSG format with whole versions of Lotus Notes NSF and Outlook file without any problem.I found a new software that works quickly on the Lotus notes data to Convert into Outlook:
Old Jan 10, 2018 | 07:15 AM
  #10
matthewrenshaw's Avatar
Convert Lotus Notes file to Outlook PST is not an easy task, both email client applications support different file format. In that condition, you need a conversion solution that can successfully migrate all NSF file data to PST format.
Supported Platforms
  • Lotus Notes- 6.0, 6.5, 7.0, 8.0 and 8.5
  • MS Outlook - 97 and all above versions
  • MS Exchange Server- all version
For more information, visit from: Domino to Exchange Tool to Deal With Lotus Notes of Domino Server to Exchange Server Email Conversion
