Right kind of oil for a new 944 engine
Old Oct 30, 2005 | 10:21 PM
nelsonjohnson's Avatar
Default Right kind of oil for a new 944 engine
What type of oil should I use in a new rebuild on a 944? I would like to use synthetic but do I need to use conventional oil to break in the motor or can I just start with the synthetic. I am just now installing the engine so it have no run time on it now. This will be an every day driver.
Thanks.
Old Oct 30, 2005 | 10:55 PM
Default RE: Right kind of oil for a new 944 engine
20w-50 castrol or if you want to go synthetic, then go 15w-50 mobil 1 or something similar. Personally, i would just run the castrol. Others would disagree.
Old Nov 1, 2005 | 09:29 PM
Well can you use the synthetic right from the start or do you need to break in the motor first?
Old Nov 1, 2005 | 09:40 PM
Use dino oil for about the first 1000 miles, then you can switch to a synthetic.
Old Nov 3, 2005 | 02:15 PM
MBS Auto Parts's Avatar
Mobile 1 !!!!
Old Nov 3, 2005 | 08:34 PM
I was thinking of AmsOil. It seems to be a better synthetic than Mobil 1. That is just what I have read.
Old Nov 3, 2005 | 08:48 PM
Amsoil wrote the book on synthetic oil. Everything mobil 1 learned about oil, they learned it from amsoil....though mobil 1 still makes a fine oil. Mobil 1 is a little easier to pick up in the store, but if you have a supplier for Amsoil, then go for it. That is all i use to run in my vehicles up north.
brandonc
Nov 16, 2012 03:55 AM
porscheforum
Nov 20, 2009 05:47 PM
suede
Sep 6, 2008 01:31 AM
brandonc
Dec 5, 2007 08:09 AM
iam
Oct 3, 2005 09:33 PM
